Update Diagram (Network Diagram Tools)
Summary
Updates one or more network diagrams that are related to a given utility network or trace network.
Diagrams may need to be updated when they are either inconsistent or consistent. When a diagram is inconsistent, it means the network elements associated with some diagram features have been altered, and the diagram is out of date. A consistent diagram may need to be updated if the diagram template associated with it has been modified.
Caution:
If you have an open edit session, you must save your edits prior to running this tool. This ensures that the diagram reflects the latest changes made to the network topology in the database. If you fail to save your edits, the edits will not be reflected in the diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Learn more about updating network diagrams
Usage
  • This tool is not supported when working with a database connection to a utility network or trace network in an enterprise geodatabase. You must use either the related published utility network or trace network service, or a utility network or trace network in a file or mobile geodatabase.
  • The input network or network diagram layer must be from either a utility network or trace network in a file or mobile geodatabase, or a utility network or trace network service.
  • If both the Input Template Names and Input Diagram Names parameters are specified, the tool will fail if the diagrams are based on a different template name.
  • If a network data element or layer is used as input, a list of diagram names or a specific diagram template is required.
  • By default, this tool only processes inconsistent diagrams. To reflect changes that may have impacted the template rule and layout definitions, and all the related diagrams (whether consistent or inconsistent), uncheck the Update inconsistent diagrams only parameter.
  • To reapply automatic layouts at the end of the diagram update, check the Re-apply automatic layouts on the updated diagrams parameter. Depending on whether the template includes a Diagram Feature Selection To Layout task, the automatic layouts apply to only the specified diagram feature selection or to the entire diagram content.
    Diagram templates support Diagram Feature Selection To Layout tasks starting at ArcGIS Enterprise 12.0 and ArcGIS Pro 3.6.
  • Attempting to update subnetwork system diagrams will fail; these diagrams are exclusively maintained by the Update Subnetwork tool.
  • This tool fails in the following situations:
    • There are dirty areas on network features initially used to generate the diagram, whether they are visible or aggregated.
    • There are dirty areas on container network features related to network objects initially used to generate the diagram, whether they are visible or aggregated.
    • There are dirty areas on new network features processed during the update.
    • There are dirty areas on container network features related to new network objects processed during the update.
    In these cases, validate the network topology to clear the dirty areas, and run the tool.
Parameters
Label Explanation Data type
Input Network or Network Diagram Layer
The input network diagram layer that will be updated, or the utility network or trace network—on which the set of specified input diagram names are based—that will be updated.
Utility Network Layer; Trace Network Layer; Utility Network; Trace Network; Diagram Layer
Template Names
(Optional)
The names of the templates for which the related diagrams will be processed.
String
Diagram Names
(Optional)
The names of the diagrams to be processed.
String
(Optional)
Specifies whether only inconsistent diagrams (the default) or all diagrams regardless of their consistency state will be updated.
  • Checked—Only inconsistent diagrams will be updated. This is the default.
  • Unchecked—Both consistent and inconsistent diagrams will be updated.
Boolean
(Optional)
Specifies whether automatic layouts that are configured on the template on which the diagrams are based will be reapplied during the update process. By default, when automatic layouts are specified on a template, they are not reapplied during the update process.
  • Checked—The automatic layouts that are configured on the template will be reapplied to diagrams at the end of the update process.
  • Unchecked—None of the automatic layouts configured on the template will be reapplied to diagrams during the update process. This is the default.
Boolean
Derived output
Output Network or Network Diagram Layer
The updated network diagram, utility network, or trace network.
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
