Overwrite Diagram (Network Diagram Tools)
Summary
Overwrites the contents of a network diagram with the network elements currently selected in the specified map. These network elements become the new initial content of the diagram.
Caution:
If you have an open edit session, you must save your edits prior to running this tool. This ensures that the diagram reflects the latest changes made to the network topology in the database. If you fail to save your edits, the edits will not be reflected in the diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Usage
This tool is not supported when working with a database connection to a utility network or trace network in an enterprise geodatabase. You must use either the related published utility network or trace network service, or a utility network or trace network in a file or mobile geodatabase.
The input network diagram layer must be from either a utility network or a trace network in a file or mobile geodatabase. or a network diagram service.
The input network diagram layer and network data in the input map must share the same utility network or trace network in a file or mobile geodatabase, or the same branch version of a utility network or trace network service.
The All Layers mode must be enabled on the input network diagram layer.
Use this tool to quickly change the contents of a diagram.
This tool can operate on network features selected in layers and network objects selected in nonspatial tables that are referenced in the input map.
Any nonnetwork elements that have been selected will not be included in the diagram. If only nonnetwork elements have been selected, the process fails.
For a temporary diagram, overwriting completely re-creates the diagram from the network elements specified as input. However, overwriting a stored diagram persists the position of the diagram features that existed in the diagram before the operation.
Running this tool on subnetwork system diagrams will fail; these diagrams are exclusively maintained by the Update Subnetwork tool. You cannot alter this type of diagram.
The Overwrite Diagram tool fails in the following situations:
There are dirty areas on input network features used to overwrite the diagram.
There are dirty areas on container network features related to network objects used as input to overwrite the diagram.
In these cases, validate the network topology to clear the dirty areas and run the tool.
Parameters
| Label | Explanation | Data type |
Input Network Diagram Layer |
The network diagram that will be overwritten. |
Diagram Layer |
Input Map |
The map referencing the set of selected network elements that will be used to overwrite the input network diagram. |
Map |
Derived output
Output Network Diagram |
The updated network diagram. |
Diagram Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
