Add Remove Feature By Attribute Rule (Network Diagram Tools)
Summary
Adds a diagram rule to the rule sequence specified on a diagram template to automatically remove diagram features during diagram buildings. The features that will be removed are queried by attributes from a given network source class or object table. You can also constrain the removal of features based on connectivity.
Learn more about the removal of features in diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The Remove Feature rule is used to remove specific network features or network objects represented in diagrams. This rule processes on network source classes or object tables, or on network categories. When the remove operation is configured to process on a network source class or object table, you can filter out these network elements by attributes. The process can also be run for specific connectivity constraints depending on the geometry type of the removed network elements.
    You can use this tool to configure the Remove Feature rule to run by attributes. This means you can configure the removal of diagram features from a given network class or object table by filtering their attributes.
    When the Remove Feature rule runs at the first position in the list of rules related to a template, it permanently deletes the initial diagram features, gaining space and improving performance for additional updates.
  • If representing network linear containers and their related contents together in diagrams is confusing or of little interest to you, you can also use this tool to remove linear container edges in diagrams (network lines or edge objects in which the Association status attribute is Container).
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Network Source to Remove
The network source class or object table that will be processed. All diagram features related to network features or objects that belong to this source class or object table are removal candidates.
Table; Feature Class
Expression
(Optional)
An SQL expression that will be used to select the subset of network elements from the element removal candidates in the diagrams based on the input template.
SQL Expression
(Optional)
The description of the rule.
String
Junctions must be unconnected
Specifies whether diagram junctions and diagram containers must be unconnected to be removed.
This parameter is only enabled when the specified Network Source to Remove parameter value corresponds to junctions or containers in the network diagrams.
  • Checked—Diagram junctions and diagram containers must be unconnected to be removed.
  • Unchecked—Diagram junctions and diagram containers do not need to be unconnected to be removed. This is the default.
Boolean
Junctions must be connected to a single junction
Specifies whether diagram junctions and diagram containers must be connected to a single diagram junction or diagram container to be removed.
  • Checked—Diagram junctions and diagram containers must be connected to a single diagram junction or diagram container to be removed.
  • Unchecked—Diagram junctions and diagram containers do not need to be connected to a single diagram junction or diagram container to be removed. This is the default.
Boolean
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
