Add Remove Feature Rule (Network Diagram Tools)
Summary
Adds a diagram rule to the rule sequence specified on a diagram template to automatically remove diagram features during diagram buildings. This rule removes diagram features based on different network source classes and object tables. You can constrain the removal of features based on connectivity.
Learn more about feature and nonspatial object removal in network diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The Remove Feature rule is used to remove specific network features or network objects represented in diagrams. This rule processes on network source classes or object tables, or on network categories. When the remove operation is configured to process on a network source class or object table, you can filter out these network elements by attributes. The process can also be run for specific connectivity constraints depending on the geometry type of the removed network elements.
    You can use this tool to configure the Remove Feature rule to remove either all diagram features that are based on specified network source classes and object tables or all diagram features except those based on the specified network source classes and object tables.
    By default, the Rule Process parameter is set to Include source classes and one or more network source classes or object tables with all their features or objects, respectively, must be systematically discarded in the generated diagram.
    When the Rule Process parameter is set to Exclude source classes, all network features and objects represented in the diagrams are removed except those based on the specified network source classes and object tables. Use this parameter to remove all features in diagrams except those representing electric transmission lines, for example, and to guarantee that diagrams showing only the electric transmission part of the network will be returned, regardless of what the end user selects as input for the diagram generation.
  • Starting with ArcGIS Pro 2.9, you can configure particular constraints based on connectivity so that the Remove Feature rule only applies to unconnected junctions or junctions connected to a single junction in the network diagram. These constraints can be set up to process network features or objects represented as diagram junctions or diagram containers.
  • You can use this tool to configure automatic discard of diagram features based on network source classes or object tables that may be present among the input network features and objects set during diagram building. For example, when an area is selected without prefiltering features and you want the diagram from this area to show only the primary equipment, you can configure the Remove Feature rule to automatically remove secondary equipment that may be present in the input network elements set.
  • When the Remove Feature rule runs at the first position in the list of rules related to a template, it permanently deletes the initial diagram features, gaining space and improving performance for additional updates.
  • If representing network linear containers and their related contents together in diagrams is confusing or of little interest, you can also use this tool to remove linear container edges from diagrams. In this case, the Remove Feature rule is typically configured at the end of the rule sequence.
  • When the SystemJunctions class exists among the specified Network Sources parameter values, the rule is systematically applied to both system junctions and system junction objects.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Source Type
Specifies the geometry type of the source class or object table that will be processed.
  • Junctions only—Only junction source classes or object tables (network polygon source classes, network point source classes, or junction object tables) will be processed.
  • Edges only—Only edge source classes or object tables (network line source classes or edge object tables) will be processed.
  • Both junctions and edges—Both junction and edge types will be processed. This is the default.
String
Rule Process
Specifies how the specified network source classes and object tables will be processed.
  • Exclude source classes—Features and objects based on the specified network source classes and object tables will not be removed, while other features and objects will be removed.
  • Include source classes—Features and objects based on the specified network source classes and object tables will be removed. This is the default.
String
Network Sources
The network source class (or classes) and object table (or tables) that will be excluded or included depending on the rule process.
By default, the Rule Process parameter is set to Include source classes, and one or more network source classes or object tables will be processed. All diagram features related to network features and objects that belong to those classes and object tables will be removed.
When specifying the SystemJunctions class among the network source classes, the rule will systematically process both system junctions and system junction objects.
Table; Feature Class
(Optional)
The description of the rule.
String
Junctions must be unconnected
Specifies whether diagram junction and diagram container candidates must be unconnected to be removed.
This parameter is only enabled when the Source Type parameter is set to Junctions only.
  • Checked—Diagram junction and diagram container candidates must be unconnected to be removed.
  • Unchecked—Neither diagram junction nor diagram container candidates need to be unconnected to be removed. This is the default.
Boolean
Junctions must be connected to a single junction
Specifies whether diagram junction and diagram container candidates must be connected to a single diagram junction or diagram container to be removed.
  • Checked—Diagram junction and diagram container candidates must be connected to a single diagram junction or diagram container to be removed.
  • Unchecked—Neither diagram junction nor diagram container candidates need to be connected to a single diagram junction or diagram container to be removed. This is the default.
Boolean
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
