Add Set Root Junction By Attribute Rule (Network Diagram Tools)
Summary
Adds a diagram rule to automatically flag diagram junctions as root junctions during diagram building based on an existing template. This rule specifies root junctions based on a particular junction source class or object table and filters using their attributes.
Learn more about setting root junctions in diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • This tool specifies junctions in a given network junction source class or object table as root junctions by filtering those junctions by their attributes.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Junction Source to Select
The network junction source class or object table to process. All diagram junctions related to network features or objects that belong to this source class or table are root junction candidates.
Table; Feature Class
Expression
(Optional)
An optional SQL expression that will be used to filter out the expected root junctions from the root junction candidates in the diagrams based on the input template.
SQL Expression
(Optional)
The description of the rule.
String
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
