Add Spatial Query Rule (Network Diagram Tools)
Summary
Adds a diagram rule that automatically appends new network features to the diagrams based on their location relative to the network features currently represented in the diagram.
Learn more about using spatial query rules to build network diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The Spatial Query rule is used to detect new network features based on their location relative to network features that currently exist in the diagram, and append the newly detected features to the network diagram.
  • The network features with which the rule works are based on the same feature class, and those features can be filtered using an SQL query expression.
  • The appended network features are based on the same feature class, and those features can be filtered using an SQL query expression.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Add Features
The source feature class to which features will be added.
Feature Class
Relationship
(Optional)
Specifies the spatial relationship between the features.
  • Intersect—The features in the Add Features source feature class will be appended to the diagram if they intersect one of the Existing Features. This is the default.
  • Within a distance—The features in the Add Features source feature class will be appended to the diagram if they are within the specified distance (using Euclidean distance) of one of the Existing Features. Use the Search Distance parameter to specify the distance.
  • Contains | Is contained of—The features in the Add Features source feature class will be appended to the diagram if they contain features from or are contained in the Existing Features.
  • Within—The features in the Add Features source feature class will be appended to the diagram if they are within the Existing Features.
  • Boundary touches—The features in the Add Features source feature class will be appended to the diagram if they have a boundary that touches one of the Existing Features. When the Existing Features are lines or polygons, the boundary of the Add Features input feature can only touch the boundary of one of the Existing Features, and no part of the input feature can cross the boundary of one of the Existing Features.
  • Share a line segment with—The features in the Add Features source feature class will be appended to the diagram if they share a line segment with one of the Existing Features. The added and existing features must be line or polygon.
  • Crossed by the outline of—The features in the Add Features source feature class will be appended to the diagram if they are crossed by the outline of one of the Existing Features. The added and existing features must be lines or polygons. If polygons are used for the Existing Features, the polygon's boundary (line) will be used. Lines that cross at a point will be appended; lines that share a line segment will not.
String
Existing Features
The source feature class on which the spatial query will run.
Feature Class
Search Distance
(Optional)
The distance between features in the Existing Features parameter and features in the Add Features parameter. This parameter is only valid if the Relationship parameter is set to Intersect, Within a distance, Contains, or Within.
Linear Unit
Added Features Query Definition
(Optional)
The SQL query that will be used to filter the features that will be added to the diagram. Without an SQL query, the features based on the specified source class that are spatially related to the specified existing features will be appended to the diagram.
SQL Expression
Existing Features Query Definition
(Optional)
The SQL query that will be used to filter the features existing in the diagram. Without an SQL query, the features based on the specified source class that exist in the diagram will be considered.
SQL Expression
(Optional)
The description of the rule.
String
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
