Create Geoprocessing Model From Diagram Template (Network Diagram Tools)
Summary
Creates a geoprocessing model with network diagram configuration tools that will set up the rules and layouts on the input diagram template.
Caution:
This tool is a configuration and administration tool.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The output geoprocessing model allows you to analyze the settings on a diagram template. To make changes, edit the rule or layout tool settings and run the model to apply the changes.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template from which the geoprocessing model will be created.
Utility Network; Trace Network
Template Name
The name of the diagram template for which the sequence of rules and layouts will be created.
String
Target Toolbox
The toolbox in which the geoprocessing model will be created.
Toolbox
Model Name
(Optional)
The name of the geoprocessing model that will be created. By default, the name of the geoprocessing model will be the same as the input diagram template name.
String
Derived output
Updated Toolbox
The updated toolbox.
Toolbox
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
