Add Images From Custom Input Type (Oriented Imagery Tools)
Summary
Adds images to an oriented imagery dataset from the input data defined by a custom input type.
Usage
  • The tool uses custom input types, implemented in Python, to define how complex or nonstandard metadata and images will be added to an oriented imagery dataset.
    The Python module must be in a folder with the same name as the module. Place the folder in [InstallDirectory]\Resources\OrientedImagery\CustomInputTypes to list the type in the Custom Input Type parameter drop-down menu. If the input type folder is in a different location, select the Folder option, and provide the folder location in the Custom Input Type Folder parameter.
  • To automate data management workflows or to work with nonstandard imagery frequently and to simplify the data management processes, define a custom input type for the data. Then use the tool to add images to an oriented imagery dataset.
  • The tool is an alternative to the Add Images To Oriented Imagery Dataset tool, which creates a .csv file with the imagery metadata in the oriented imagery table schema to add images to an oriented imagery dataset.
Parameters
Label Explanation Data type
The path and name of the oriented imagery dataset where the images will be added.
Oriented Imagery Layer
Custom Input Type
The name of the custom input type.
To select an input type that is not listed, use the Folder option. This parameter value will activate the Custom Input Type Folder parameter.
String
The path to the custom input type folder. The folder must contain a Python module with the same name as the folder and the required public functions.
Folder
Input Data
The name and the path or value of the input data. The selected custom input type determines the available options.
Value table columns:
  • Name—Specifies the name of the input data.
  • Value—Specifies the path or value for the input data.
Value Table
Auxiliary Parameters
The names and values of any auxiliary parameters defined in the input type schema.
  • Name—Specifies the name of the auxiliary parameter.
  • Value—Specified the value of the auxiliary parameter.
Value Table
Derived output
Output Oriented Imagery Dataset
The updated output oriented imagery dataset.
Environments
Output Coordinate System, Geographic Transformations, Extent
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
