Build Oriented Imagery Footprint (Oriented Imagery Tools)
Summary
Builds a footprint feature class for an oriented imagery dataset.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • If the Footprint Options parameter is set to One footprint per image or Merge all image footprints., the output footprints will be calculated by computing each image extent. You can adjust the image extent by changing the Camera Heading, Camera Roll, Horizontal Field of View, Vertical Field of View, Camera Height, Far Distance, and Near Distance values in the oriented imagery dataset's attribute table. For 360 degree images, the extent depends only on the Far Distance value. If these values are not defined in the oriented imagery dataset's attribute table, the default values from the oriented imagery dataset properties will be used.
  • The output feature class will be added as the Footprint property of the oriented imagery dataset only if the Footprint Dataset Location parameter value is the same geodatabase as that of the oriented imagery dataset.
Parameters
Label Explanation Data type
Oriented Imagery Dataset
The oriented imagery dataset for which the footprint will be computed.
Oriented Imagery Layer
The enterprise or file geodatabase where the output footprint feature class will be created.
Workspace; Feature Dataset
Footprint Dataset Name
The name of the output footprint feature class.
String
Footprint Options
Specifies the method that will be used to create the footprint.
  • One footprint per image—Polygon features will be created from each feature based on camera parameters. Use this option when there are only a few feature points and they are scattered over a large projected area.
  • Merge all image footprints—Individual polygons will be computed and merged into a single polygon feature that is a more optimized footprint for the dataset.
  • Buffer each camera location—Each feature point will be buffered using the average far distance value of the oriented imagery dataset and merged to a single polygon feature. Use this option for street view imagery.
  • Dataset extent as footprint—A footprint will be created based on the extent of the oriented imagery dataset. Use this option when there are many camera points within a small area.
String
Derived output
Output Footprint
The output footprint feature class.
Feature Class
Environments
Output Coordinate System, Geographic Transformations, Extent
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
