Calculate Distance (Raster Analysis Tools)
Summary
Calculates the Euclidean distance from a single source or set of sources.
Legacy:
This tool is deprecated and will be removed in a future release.
The Distance Accumulation or Distance Allocation tools provide enhanced functionality or performance.
Illustration
Calculate Distance tool illustration
Usage
  • This raster analysis portal tool is available when you are signed in to an ArcGIS Enterprise portal that has ArcGIS Image Server configured for Raster Analysis. When the tool is run, ArcGIS Pro serves as a client and the processing occurs in the servers federated with ArcGIS Enterprise. The portal tool accepts layers from your portal as input and creates output in your portal.
    The input raster layer supports a layer from the portal, a URI or URL to an image service, or the output from the Make Image Server Layer tool. The input feature layer can be a layer from the portal or a URI or URL to a feature service. This tool does not support local raster data or layers. While you can use local feature data and layers as input to this portal tool, best practice is to use layers from your portal as input.
  • One example application of this tool is finding the distance from any location to the closest town.
  • When the input source data is an image service, the set of source cells consists of all cells in the source raster that have valid values. Cells that have NoData values are not included in the source set. The value 0 is considered a legitimate source.
  • When the input source data is a feature service, the source locations are converted internally to a raster before performing the analysis. The resolution of the raster can be controlled with the Output cell size parameter or the Cell Size environment. By default, the resolution will be determined by the shorter of the width or height of the extent of input feature, in the input spatial reference, divided by 250.
Parameters
Label Explanation Data type
Input Source Raster or Features
The layer that defines the sources to calculate the distance to. The layer can be image service or feature service.
For image service, the input type can be integer or floating point.
For feature service, the input can be point, line or polygon.
Raster Layer; Image Service; Feature Layer; String
Output Distance Name
The name of the output distance raster service.
String
Maximum Distance
(Optional)
The maximum distance to calculate out to.
The unit values are Kilometers, Meters, Statute Miles, International Yards, International Feet, US Survey Miles, US Survey Yards, and US Survey Feet.
The default units are meters.
Linear Unit
Output Cell Size
(Optional)
Set the cell size and units for the output raster.
Linear Unit
Output Direction Name
(Optional)
The name of the output direction raster service.
String
Output Allocation Name
(Optional)
The name of the output allocation raster service.
String
Allocation Field
(Optional)
A field on the source input that holds the values that define each source. It must be of type integer.
String
Distance Method
(Optional)
Specifies whether to calculate the distance using a planar (flat earth) or a geodesic (ellipsoid) method.
  • Planar—The distance calculation will be performed on a projected flat plane using a 2D Cartesian coordinate system. This is the default.
  • Geodesic—The distance calculation will be performed on the ellipsoid. Therefore, regardless of input or output projection, the results do not change.
String
Input Barrier Raster or Features
(Optional)
Dataset that defines the barriers.
The barriers can be defined by an integer or floating point raster, or a feature layer.
Output Back Direction Name
(Optional)
The name of the output back direction raster service.
String
Derived output
Output Distance Raster
The output distance raster.
Raster Layer
Output Direction Raster
The output direction raster.
Raster Layer
Output Back Direction Raster
The output back direction raster.
Raster Layer
Output Allocation Raster
The output allocation raster.
Raster Layer
Environments
Cell Size, Extent, Mask, Output Coordinate System, Pyramid, Snap Raster
Licensing information
  • Basic: Requires ArcGIS Image Server
  • Standard: Requires ArcGIS Image Server
  • Advanced: Requires ArcGIS Image Server
