Flow Distance (Raster Analysis Tools)
Summary
Computes, for each cell, the horizontal or vertical component of downslope distance, following the flow paths, to cells on a stream into which they flow. In the case of multiple flow paths, minimum, weighted mean, or maximum flow distance can be computed.
If an optional flow direction raster is provided, the down slope directions will be limited to those defined by the input flow direction raster.
Illustration
Flow Distance tool illustration
Usage
  • This raster analysis portal tool is available when you are signed in to an ArcGIS Enterprise portal that has ArcGIS Image Server configured for Raster Analysis. When the tool is run, ArcGIS Pro serves as a client and the processing occurs in the servers federated with ArcGIS Enterprise. The portal tool accepts layers from your portal as input and creates output in your portal.
    The input raster layer supports a layer from the portal, a URI or URL to an image service, or the output from the Make Image Server Layer tool. This tool does not support local raster data or layers.
  • To limit downslope directions along which flow distance is measured, provide an optional input flow direction raster that can be derived using the Flow Direction tool. Choose from D8, D-Infinity (DINF) and multi flow direction (MFD) flow models while generating an optional input flow direction raster. Use the Input flow direction type to specify which method was used when the flow direction raster was created.
  • If an optional input flow direction raster is provided, it is recommended that this raster be created using the Flow Direction tool using the same input surface raster that you'll provide to the Flow Distance tool.
    If this input surface raster is void of sinks, the distance measurements will be to stream cells represented by the input stream raster.
    If this input surface raster has sinks present, some flow paths may be terminated short by flowing into sinks before reaching streams. In such cases, flow distance measurements for these cells are calculated only up to the sink cells into which they flow.
  • When the tool is run without an optional flow direction raster, flow distance is assessed by considering all possible downslope flow paths from each cell to cells on a stream into which they flow.
    When the tool is run with an optional D8 flow direction raster, there is only one possible downslope flow path from every cell to a cell on the stream, and flow distance is measured along this single flow path.
  • It is recommended to create the input stream raster using the same input surface raster that is provided as input to the tool. If you have a Spatial Analyst extension license available, you can create stream rasters from an input surface raster using the Flow Direction, Flow Accumulation and Con tools respectively. If you wish to use streams from other data sources, for best results, you would have to burn them into the input surface raster first and then running the Flow Distance tool.
  • When multiple flow paths exist from each cell to cells on the stream into which they flow, use the Statistics type to compute minimum, weighted mean, or maximum flow distance.
    If there exists only a single flow path from each cell to a cell on the stream, all statistics types produce the same result.
Parameters
Label Explanation Data type
Input Stream Raster
The input raster that defines the stream network.
Raster Layer; Image Service; String
Input Surface Raster
The input raster representing a continuous surface.
Output Name
The name of the output flow distance raster service.
The default name is based on the tool name and the input layer name. If the layer name already exists, you will be prompted to provide another name.
String
Input Flow Direction Raster
(Optional)
The input raster that shows the direction of flow out of each cell.
When a flow direction raster is provided, the down slope direction(s) will be limited to those defined by the input flow directions.
The flow direction raster can be created using the D8, MFD, or DINF method. Use the Flow Direction Type parameter to specify the method used when the flow direction raster was created.
Distance Type
(Optional)
The distance type to be calculated.
  • Vertical—The flow distance calculations represent the vertical component of minimum flow distance, following the flow path, from each cell in the domain to cell(s) on the stream into which they flow. This is the default.
  • Horizontal—The flow distance calculations represent the horizontal component of minimum flow distance, following the flow path, from each cell in the domain to cell(s) on the stream into which they flow.
String
Flow Direction Type
(Optional)
Specifies the input flow direction raster type.
  • D8—The input flow direction raster is of type D8. This is the default.
  • MFD—The input flow direction raster is of type Multi Flow Direction (MFD).
  • DINF—The input flow direction raster is of type D-Infinity (DINF).
String
Statistics type
(Optional)
Determines the statistics type used to compute flow distance over multiple flow paths.
  • Minimum—Where multiple flow paths exist, minimum flow distance is computed. This is the default.
  • Weighted Mean—Where multiple flow paths exist, a weighted mean of flow distance is computed. Flow proportion from a cell to its downstream neighboring cells is used as a weight for computing weighted mean.
  • Maximum—When multiple flow paths exist, maximum flow distance is computed.
String
Derived output
Output Raster
The output raster.
Raster Layer
Environments
Cell Size, Extent, Mask, Output Coordinate System, Pyramid, Snap Raster
Licensing information
  • Basic: Requires ArcGIS Image Server
  • Standard: Requires ArcGIS Image Server
  • Advanced: Requires ArcGIS Image Server
