Flow Accumulation (Spatial Analyst Tools)
Summary
Creates a raster of accumulated flow into each cell. A weight factor can be applied.
Learn more about how Flow Accumulation works
Illustration
D8 Flow Accumulation illustration
Flow_Acc = FlowAccumulation(Flow_Dir)
Usage
  • The result of Flow Accumulation is a raster of accumulated flow to each cell, as determined by accumulating the weight for all cells that flow into each downslope cell.
  • The Flow Accumulation tool supports three flow modeling algorithms while computing accumulated flow. These are D8, Multiple Flow Direction (MFD) and D-Infinity (DINF) flow methods.
  • If the input flow direction raster is not created with the Flow Direction tool, there is a chance that the defined flow could loop. If the flow direction contains a loop, Flow Accumulation will go into an endless cycle and never finish.
    Input flow direction can be created using the D8, Multiple Flow Direction (MFD) or D-Infinity (DINF) methods. The type of input flow direction raster between these three influences how the Flow Accumulation tool partitions and accumulates flow in each cell. Use the Input flow direction type to specify which method was used when the flow direction raster was created.
  • Cells of undefined flow direction will only receive flow; they will not contribute to any downstream flow.
    For an input D8 flow direction raster, a cell is considered to have an undefined flow direction if its value in the flow direction raster is anything other than 1, 2, 4, 8, 16, 32, 64, or 128.
    For an input D-Infinity flow direction raster, a cell is considered to have an undefined flow direction if its value in the flow direction raster is -1.
  • The accumulated flow is based on the number of total or a fraction of cells flowing into each cell in the output raster. The current processing cell is not considered in this accumulation.
  • Output cells with a high flow accumulation are areas of concentrated flow and can be used to identify stream channels.
  • Output cells with a flow accumulation of zero are local topographic highs and can be used to identify ridges.
  • The Flow Accumulation tool does not honour the Compression environment setting. The output raster will always be uncompressed.
  • This tool supports parallel processing. If your computer has multiple processors or processors with multiple cores, better performance may be achieved, particularly on larger datasets. The Parallel processing with Spatial Analyst help topic includes details about this capability and how to configure it.
    When using parallel processing, temporary data will be written to manage the data chunks being processed. The default temp folder location will be on your local C: drive. You can control the location of this folder by setting up a system environment variable named TempFolders and specifying the path to a folder to use (for example, E:\RasterCache). If you have administrator privileges on your machine, you can also use a registry key (for example, [HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Raster]).
    By default, this tool will use 50 percent of the available cores. If the input data is smaller than 5,000-by-5,000 cells in size, fewer cores may be used. You can control the number of cores the tool uses with the Parallel processing factor environment.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input flow direction raster
The input raster that shows the direction of flow out of each cell.
The flow direction raster can be created using the Flow Direction tool.
The flow direction raster can be created using the D8, Multiple Flow Direction (MFD), or D-Infinity method. Use the Input flow direction type parameter to specify the method used when the flow direction raster was created.
Raster Layer
Input weight raster
(Optional)
An input raster for applying a weight to each cell.
If no weight raster is specified, a default weight of 1 will be applied to each cell. For each cell in the output raster, the result will be the number of cells that flow into it.
Raster Layer
Output data type
(Optional)
The output accumulation raster can be integer, floating point, or double type.
  • Float—The output raster will be floating point type. This is the default.
  • Integer—The output raster will be integer type.
  • Double—The output raster will be double type.
String
(Optional)
Specifies the input flow direction raster type.
  • D8—The input flow direction raster is of type D8. This is the default.
  • MFD—The input flow direction raster is of type Multi Flow Direction (MFD).
  • DINF—The input flow direction raster is of type D-Infinity (DINF).
String
Return value
Output accumulation raster
The output raster that shows the accumulated flow to each cell.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
