Compute Confusion Matrix (Spatial Analyst Tools)
Summary
Computes a confusion matrix with errors of omission and commission and derives a kappa index of agreement, Intersection over Union (IoU), and overall accuracy between the classified map and the reference data.
This tool uses the outputs from the Create Accuracy Assessment Points tool or the Update Accuracy Assessment Points tool.
Usage
  • The accuracy assessment workflow usually uses the following three tools in this order: Create Accuracy Assessment Points, Update Accuracy Assessment Points, and Compute Confusion Matrix.
  • This tool computes a confusion matrix using the random accuracy assessment points. The accuracy assessment points are generated by the Create Accuracy Assessment Points tool and updated by the Update Accuracy Assessment Points tool. These two tools ensure that each point will have valid class values for the Classified and GrndTruth fields. These fields are both long integer field types. The tool calculates the user's accuracy and producer's accuracy for each class as well as an overall kappa index of agreement. These accuracy rates range from 0 to 1 in which 1 represents 100 percent accuracy. The following is an example of a confusion matrix:
    c_1
    c_2
    c_3
    Total
    U_Accuracy
    Kappa
    c_1
    49
    0.8594
    c_2
    0.9091
    c_3
    65
    0.9077
    Total
    54
    47
    65
    166
    P_Accuracy
    0.9074
    0.8511
    0.9077
    Kappa
    Confusion matrix example
  • User accuracy is a measure of the pixels that are correctly classified out of all the pixels that are classified as a given class. The remainder of the pixels classified into this class belong to a different class, or are identified as a different class, according to the reference information; they are false positives.
    User accuracy is also referred to as errors of commission, or type 1 error. The data to compute this error rate is read from the rows of the table.
    The Total row shows the number of points that should have been identified as a given class according to the reference data.
  • Producer accuracy is a false negative in which pixels of a known class are classified as something other than that class. An example is when the classified image identifies a pixel as forest, but it should be impervious. In this case, the impervious class is missing pixels according to the reference data.
    Producer accuracy is also referred to as errors of omission, or type 2 error. The data to compute this error rate is read from the columns of the table.
    The Total column shows the number of points that were identified as a given class according to the classified map.
  • Kappa index of agreement provides an overall assessment of the accuracy of the classification.
  • Intersection over Union (IoU) is the area of overlap between the predicted segmentation and the ground truth divided by the area of union between the predicted segmentation and the ground truth. The mean IoU value is computed for each class.
Parameters
Label Explanation Data type
Input Accuracy Assessment Points
The accuracy assessment point feature class created from the Create Accuracy Assessment Points tool, containing the Classified and GrndTruth fields. These fields are both long integer field types.
Feature Layer
Output Confusion Matrix
The output file name of the confusion matrix in table format.
The format of the table is determined by the output location and path. By default, the output will be a geodatabase table. If the path is not in a geodatabase, specify the .dbf extension to save it in dBASE format.
Table
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
