An overview of the Segmentation and Classification toolset
Available with Spatial Analyst license.
Available with Image Analyst license.
With the segmentation and classification tools, you can prepare segmented rasters to use in creating classified raster datasets.
The following table lists the available tools and provides a brief description of each:
Tool
Classify Raster
Classifies a raster dataset based on an Esri classifier definition file (.ecd) and raster dataset inputs.
The .ecd file contains all the information needed to perform a specific type of Esri-supported classification. The inputs to this tool must match the inputs used to generate the required .ecd file.
Compute Confusion Matrix
Computes a confusion matrix with errors of omission and commission and derives a kappa index of agreement, Intersection over Union (IoU), and overall accuracy between the classified map and the reference data.
Compute Segment Attributes
Computes a set of attributes associated with the segmented image. The input raster can be a single-band or 3-band, 8-bit segmented image.
Create Accuracy Assessment Points
Creates randomly sampled points for postclassification accuracy assessment.
Export Training Data For Deep Learning
Converts labeled vector or raster data to deep learning training datasets using a remote sensing image. The output is a folder of image chips and a folder of metadata files in the specified format.
Generate Training Samples From Seed Points
Generates training samples from seed points, such as accuracy assessment points or training sample points. A typical use case is generating training samples from an existing source, such as a thematic raster or a feature class.
Inspect Training Samples
Estimates the accuracy of individual training samples. The cross validation accuracy is computed using the previously generated classification training result in an .ecd file and the training samples. Outputs include a raster dataset containing the misclassified class values and a training sample dataset with the accuracy score for each training sample.
Linear Spectral Unmixing
Performs subpixel classification and calculates the fractional abundance of different land-cover types for individual pixels.
Remove Raster Segment Tiling Artifacts
Corrects segments or objects cut by tile boundaries during the segmentation process performed as a raster function. This tool is helpful for some regional processes, such as image segmentation, that have inconsistencies near image tile boundaries.
This processing step is included in the Segment Mean Shift tool. It should only be used on a segmented image that was not created from that tool.
Segment Mean Shift
Groups adjacent pixels that have similar spectral characteristics into segments.
Train Iso Cluster Classifier
Generates an Esri classifier definition file (.ecd) using the Iso Cluster classification definition.
Train K-Nearest Neighbor Classifier
Generates an Esri classifier definition file (.ecd) using the K-Nearest Neighbor classification method.
Train Maximum Likelihood Classifier
Generates an Esri classifier definition file (.ecd) using the Maximum Likelihood Classifier (MLC) classification definition.
Train Random Trees Classifier
Generates an Esri classifier definition file (.ecd) using the Random Trees classification method.
Train Support Vector Machine Classifier
Generates an Esri classifier definition file (.ecd) using the Support Vector Machine (SVM) classification definition.
Update Accuracy Assessment Points
Updates the Target field in the attribute table to compare reference points to the classified image.
Tools of the Segmentation and Classification toolset
