Train ISO Cluster Classifier (Spatial Analyst Tools)
Summary
Generates an Esri classifier definition file (.ecd) using the Iso Cluster classification definition.
This tool performs an unsupervised classification.
Usage
  • Any Esri-supported raster is accepted as input, including raster products, segmented raster, mosaics, image services, or generic raster datasets. Segmented rasters must be 8-bit rasters with 3-bands.
  • The Segment Attributes parameter is only active if one of the raster layer inputs is a segmented image.
Parameters
Label Explanation Data type
Input Raster
The raster dataset to classify.
Raster Layer; Mosaic Layer; Image Service; String
Maximum Number Of Classes / Clusters
Maximum number of desired classes to group pixels or segments. This should be set to be greater than the number of classes in your legend.
It is possible that you will get fewer classes than what you specified for this parameter. If you need more, increase this value and aggregate classes after the training process is complete.
Long
Output Classifier Definition File
The output JSON format file that will contain attribute information, statistics, hyperplane vectors, and other information for the classifier. An .ecd file will be created.
File
Additional Input Raster
(Optional)
Ancillary raster datasets, such as a multispectral image or a DEM, will be incorporated to generate attributes and other required information for classification. This parameter is optional.
Maximum Number Of Iterations
(Optional)
The maximum number of iterations the clustering process will run.
The recommended range is between 10 and 20 iterations. Increasing this value will linearly increase the processing time.
Long
Minimum Number of Samples Per Cluster
(Optional)
The minimum number of pixels or segments in a valid cluster or class.
The default value of 20 is effective in creating statistically significant classes. You can increase this number for more larger clusters and less slivers; however, it may limit the overall number of classes that are created.
Long
Skip Factor
(Optional)
Number of pixels to skip for a pixel image input. If a segmented image is an input, specify the number of segments to skip.
Long
Segment Attributes Used
(Optional)
Specifies the attributes that will be included in the attribute table associated with the output raster.
This parameter is only active if the Segmented key property is set to true on the input raster. If the only input to the tool is a segmented image, the default attributes are Converged color, Count of pixels, Compactness, and Rectangularity. If an Additional Input Raster value is included as an input with a segmented image, Mean digital number and Standard deviation are also available attributes.
  • Converged color—The RGB color values will be derived from the input raster on a per-segment basis. This is also known as average chromaticity color.
  • Mean digital number—The average digital number (DN) will be derived from the optional pixel image on a per-segment basis.
  • Standard deviation—The standard deviation will be derived from the optional pixel image on a per-segment basis.
  • Count of pixels—The number of pixels composing the segment, on a per-segment basis.
  • Compactness—The degree to which a segment is compact or circular, on a per-segment basis. The values range from 0 to 1, in which 1 is a circle.
  • Rectangularity—The degree to which the segment is rectangular, on a per-segment basis. The values range from 0 to 1, in which 1 is a rectangle.
String
Maximum Number Of Cluster Merges per Iteration
(Optional)
The maximum number of cluster merges per iteration. Increasing the number of merges will reduce the number of classes that are created. A lower value will result in more classes.
Long
Maximum Merge Distance
(Optional)
The maximum distance between cluster centers in feature space. Increasing the distance will allow more clusters to merge, resulting in fewer classes. A lower value will result in more classes. Values from 0 to 5 typically return the best results.
Double
Environments
Current Workspace, Extent, Geographic Transformations, Output Coordinate System, Parallel Processing Factor, Scratch Workspace, Snap Raster
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
