Compute Segment Attributes (Spatial Analyst Tools)
Summary
Computes a set of attributes associated with the segmented image. The input raster can be a single-band or 3-band, 8-bit segmented image.
Usage
  • This tool generates the attributes for each segment that exists in the image. Attributes include mean, standard deviation, segment size, converged color (from the Segment Mean Shift tool), and compactness.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input Segmented RGB Or Gray Raster
The input segmented raster dataset, where all the pixels belonging to a segment have the same converged RGB color. Usually, it is an 8-bit, 3-band RGB raster, but it can also be a 1-band grayscale raster.
Raster Layer; Mosaic Layer
Additional Input Raster
(Optional)
Ancillary raster datasets, such as a multispectral image or a DEM, will be incorporated to generate attributes and other required information for the classifier. This raster is necessary when calculating attributes such as mean or standard deviation. This parameter is optional.
Segment Attributes Used
(Optional)
Specifies the attributes that will be included in the attribute table associated with the output raster.
If the only input into the tool is a segmented image, the default attributes are Average chromaticity color, Count of pixels, Compactness, and Rectangularity. If an Additional Input Raster is also included as an input along with a segmented image, then Mean digital number and Standard deviation are available as options.
  • Converged color—The RGB color values will be derived from the input raster on a per-segment basis. This is also known as average chromaticity color.
  • Mean digital number—The average digital number (DN) will be derived from the optional pixel image on a per-segment basis.
  • Standard deviation—The standard deviation will be derived from the optional pixel image on a per-segment basis.
  • Count of pixels—The number of pixels composing the segment, on a per-segment basis.
  • Compactness—The degree to which a segment is compact or circular, on a per-segment basis. The values range from 0 to 1, in which 1 is a circle.
  • Rectangularity—The degree to which the segment is rectangular, on a per-segment basis. The values range from 0 to 1, in which 1 is a rectangle.
String
Return value
Output Segment Index Raster
The output segment index raster, where the attributes for each segment are recorded in the associated attribute table.
Raster
Environments
Compression, Current Workspace, Extent, Geographic Transformations, Output Coordinate System, NoData, Parallel Processing Factor, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
