Remove Raster Segment Tiling Artifacts (Spatial Analyst Tools)
Summary
Corrects segments or objects cut by tile boundaries during the segmentation process performed as a raster function. This tool is helpful for some regional processes, such as image segmentation, that have inconsistencies near image tile boundaries.
This processing step is included in the Segment Mean Shift tool. It should only be used on a segmented image that was not created from that tool.
Usage
  • This tool can be used with the Generate Raster from Raster Function geoprocessing tool, which allows you to use the segmentation raster function in a parallel processing environment and write the output to disk.
Parameters
Label Explanation Data type
Input Segmented RGB Or Gray Raster
Select the segmented raster with the tiling artifacts that you want to remove.
Raster Dataset; Mosaic Dataset; Raster Layer; Mosaic Layer; Image Service; String
Tile width used for segmentation
(Optional)
Specify the tile width from Segment Mean Shift. If left blank, the default is 512 pixels.
Long
Tile height used for segmentation
(Optional)
Specify the tile height from Segment Mean Shift. If left blank, the default is 512 pixels.
Long
Return value
Output Segmented Raster
The path and name of the segmented raster from which you are removing tiling artifacts.
Raster
Environments
Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Resampling Method, Scratch Workspace, Snap Raster, Raster Statistics, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
