Train K-Nearest Neighbor Classifier (Spatial Analyst Tools)
Summary
Generates an Esri classifier definition file (.ecd) using the K-Nearest Neighbor classification method.
The K-Nearest Neighbor classifier is a nonparametric classification method that classifies a pixel or segment by a plurality vote of its neighbors. K is the defined number of neighbors used in voting.
Usage
  • The tool assigns training samples to their respective classes. The class of the input pixel is determined by a plurality vote of its K-nearest neighbors.
  • Any Esri-supported raster is accepted as input, including raster products, segmented rasters, mosaics, image services, and generic raster datasets. Segmented rasters must be 8-bit rasters with three bands.
  • The output of this tool is an .ecd file that is used to classify new rasters in the Classify Raster tool. The Classify Raster tool then calculates the distance from each input pixel or segment to all training samples.
    The training sample data must have been collected at multiple times using the Training Samples Manager. The dimension value for each sample is listed in a field in the training sample feature class, which is specified in the Dimension Value Field parameter.
  • To create the training sample file, use the Training Samples Manager pane from the Classification Tools drop-down menu.
  • For segmented rasters that have their key property set to Segmented, the tool computes the index image and associated segment attributes from the RGB segmented raster. The attributes are computed to generate the classifier definition file to be used in a separate classification tool. The attributes for each segment can be computed from any Esri-supported image.
  • The Segment Attributes parameter is only active if one of the raster layer inputs is a segmented image.
Parameters
Label Explanation Data type
Input Raster
The raster dataset to classify.
The single band raster or segmented raster, multiband raster, or a multidimensional raster to be classified.
Mosaic Layer; Raster Layer; Image Service; String
Input Training Sample File
The training sample file or layer that delineates the training sites.
These can be either shapefiles or feature classes that contain the training samples. The following field names are required in the training sample file:
  • classname—A text field indicating the name of the class category
  • classvalue—A long integer field containing the integer value for each class category
Feature Layer
Output Classifier Definition File
A JSON formatted .ecd file that contains attribute information, statistics, or other information for the classifier.
File
Additional Input Raster
(Optional)
Ancillary raster datasets, such as a multispectral image or a DEM, will be incorporated to generate attributes and other required information for classification. This parameter is optional.
Raster Layer; Mosaic Layer; Image Service; String
K Nearest Neighbors
(Optional)
The number of neighbors that will be used in searching for each input pixel or segment. Increasing the number of neighbors will decrease the influence of individual neighbors on the outcome of the classification. The default value is 1.
Long
Max Number of Samples Per Class
(Optional)
The maximum number of training samples that will be used for each class. The default value of 1000 is recommended when the inputs are nonsegmented rasters. A value that is less than or equal to 0 means that the system will use all the samples from the training sites to train the classifier.
Long
Segment Attributes
(Optional)
Specifies the attributes that will be included in the attribute table associated with the output raster.
This parameter is only active if the Segmented key property is set to true on the input raster. If the only input to the tool is a segmented image, the default attributes are Converged color, Count of pixels, Compactness, and Rectangularity. If an Additional Input Raster value is included as an input with a segmented image, Mean digital number and Standard deviation are also available attributes.
  • Converged color—The RGB color values will be derived from the input raster on a per-segment basis. This is also known as average chromaticity color.
  • Mean digital number—The average digital number (DN) will be derived from the optional pixel image on a per-segment basis.
  • Standard deviation—The standard deviation will be derived from the optional pixel image on a per-segment basis.
  • Count of pixels—The number of pixels composing the segment, on a per-segment basis.
  • Compactness—The degree to which a segment is compact or circular, on a per-segment basis. The values range from 0 to 1, in which 1 is a circle.
  • Rectangularity—The degree to which the segment is rectangular, on a per-segment basis. The values range from 0 to 1, in which 1 is a rectangle.
String
(Optional)
Contains dimension values in the input training sample feature class.
This parameter is required to classify a time series of raster data using the change analysis raster output from the Analyze Changes Using CCDC tool in the Image Analyst toolbox.
Field
Environments
Current Workspace, Extent, Geographic Transformations, Output Coordinate System, Scratch Workspace, Snap Raster
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
