Train Maximum Likelihood Classifier (Spatial Analyst Tools)
Summary
Generates an Esri classifier definition file (.ecd) using the Maximum Likelihood Classifier (MLC) classification definition.
Usage
  • To complete the maximum likelihood classification process, use the same input raster and the output .ecd file from this tool in the Classify Raster tool.
  • The input raster can be any Esri-supported raster with any valid bit depth.
  • To create a segmented raster dataset, use the Segment Mean Shift tool.
  • To create the training sample file, use the Training Samples Manager pane from the Classification Tools drop-down menu.
  • The Output Classifier Definition File contains attribute statistics suitable for the Maximum Likelihood Classification tool.
  • The Segment Attributes parameter is only active if one of the raster layer inputs is a segmented image.
  • To classify time series raster data using the Continuous Change Detection and Classification (CCDC) algorithm, first run the Analyze Changes Using CCDC tool, which is available with an Image Analyst extension license. Next, use those results as input to this training tool.
    The training sample data must have been collected at multiple times using the Training Samples Manager. The dimension value for each sample is listed in a field in the training sample feature class, which is specified in the Dimension Value Field parameter.
Parameters
Label Explanation Data type
Input Raster
The raster dataset to classify.
Raster Layer; Mosaic Layer; Image Service; String
Input Training Sample File
The training sample file or layer that delineates the training sites.
These can be either shapefiles or feature classes that contain the training samples. The following field names are required in the training sample file:
  • classname—A text field indicating the name of the class category
  • classvalue—A long integer field containing the integer value for each class category
Feature Layer
The output JSON format file that will contain attribute information, statistics, hyperplane vectors, and other information for the classifier. An .ecd file will be created.
File
Additional Input Raster
(Optional)
Incorporates ancillary raster datasets, such as a segmented image or DEM. This parameter is optional.
Segment Attributes Used
(Optional)
Specifies the attributes that will be included in the attribute table associated with the output raster.
This parameter is only active if the Segmented key property is set to true on the input raster. If the only input to the tool is a segmented image, the default attributes are Converged color, Count of pixels, Compactness, and Rectangularity. If an Additional Input Raster value is included as an input with a segmented image, Mean digital number and Standard deviation are also available attributes.
  • Converged color—The RGB color values will be derived from the input raster on a per-segment basis. This is also known as average chromaticity color.
  • Mean digital number—The average digital number (DN) will be derived from the optional pixel image on a per-segment basis.
  • Standard deviation—The standard deviation will be derived from the optional pixel image on a per-segment basis.
  • Count of pixels—The number of pixels composing the segment, on a per-segment basis.
  • Compactness—The degree to which a segment is compact or circular, on a per-segment basis. The values range from 0 to 1, in which 1 is a circle.
  • Rectangularity—The degree to which the segment is rectangular, on a per-segment basis. The values range from 0 to 1, in which 1 is a rectangle.
String
(Optional)
Contains dimension values in the input training sample feature class.
This parameter is required to classify a time series of raster data using the change analysis raster output from the Analyze Changes Using CCDC tool in the Image Analyst toolbox.
Field
Environments
Current Workspace, Extent, Geographic Transformations, Output Coordinate System, Scratch Workspace, Snap Raster
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
