Update Accuracy Assessment Points (Spatial Analyst Tools)
Summary
Updates the Target field in the attribute table to compare reference points to the classified image.
Accuracy assessment uses known points to assess the validity of the classification model.
Usage
  • Use this tool to update the attribute table of a feature class that represents accuracy assessment points. If you created the feature class using the Create Accuracy Assessment Points tool, a GROUND_TRUTH field and a CLASSIFIED field are included in the table. This tool can start with the reference data and compare it to the classified output, or it can start with the classified output and compare it to the reference data.
    You can then compare the two fields using the Compute Confusion Matrix tool.
  • The accuracy assessment workflow usually uses the following three tools in this order: Create Accuracy Assessment Points, Update Accuracy Assessment Points, and Compute Confusion Matrix.
  • When a polygon feature class is used for training or accuracy assessment, the feature class must have a Classvalue or value field that has a unique integer value for each class. For example, a polygon feature class with three different classes can have values such as [1, 2, 3] or [10, 20, 40].
  • You can manually update the GROUND_TRUTH field to change or identify a set of points.
  • When the Input Raster or Feature Class Data parameter value is a multidimensional raster, the time dimension (StdTime field) will be used automatically. If a fourth dimension exists (for example, Z field), the first dimension value will be used. You can use the Make Multidimensional Raster Layer tool or the Subset Multidimensional Raster tool to configure the input.
Parameters
Label Explanation Data type
The input classification image or other thematic GIS reference data. The input can be a raster or feature class.
Typical data is a classification image of a single band of integer data type.
If using polygons as input, only use those that are not used as training samples. They can also be GIS land-cover data in shapefile or feature class format.
Raster Layer; Mosaic Layer; Feature Layer
Input Accuracy Assessment Points
The point feature class with the accuracy assessment points that will be updated.
All points from this input will be copied to the updated output feature class, and the Target Field parameter value will be updated from the input raster or feature class data.
Feature Layer
Output Accuracy Assessment Points
The output point shapefile or feature class that contains the random points that will be used for accuracy assessment.
Feature Class
Target Field
(Optional)
Specifies whether the input data is a classified image or ground truth data.
A classified image is the image that was just classified. Ground truth data, or reference data, consists of identified features and will be compared to the classified results for quality assurance.
  • Classified—The input is a classified image. This is the default.
  • Ground truth—The input is reference data.
String
Dimension Field for Feature Class
(Optional)
The dimension field for the Input Accuracy Assessment Points parameter value. The assessment points will be updated based on the matching dimension values with this field.
Field
Dimension Field for Test Points
(Optional)
The dimension field in the Input Accuracy Assessment Points parameter value. Input data with identical dimension values will be used to update corresponding points.
When the Input Raster or Feature Class Data parameter value is a multidimensional raster, rasters with dimension values that match the dimension field in the test points will be used in updating. The multidimensional raster is expected to have one time dimension (StdTime field). Otherwise, the first dimension will be used to match the dimension field of the test points.
Field
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
