Optimal Path As Raster (Spatial Analyst Tools)
Summary
Calculates the optimal path from a source to a destination as a raster.
Learn more about connecting locations with optimal paths
Usage
  • The Optimal Path As Raster tool produces an output raster.
  • When the input destination data is a raster, the set of destination cells consists of all cells in the Input Raster or Feature Destination parameter value that have valid values. Cells that have NoData values are not included in the source set. Zero is a valid value. A destination raster can be created using the extraction tools.
  • When using polygon feature data for the input feature destinations, care must be taken with how the output cell size is handled, particularly when it is coarse relative to the detail present in the input. An internal rasterization process using the Polygon to Raster tool is applied with the default setting for Cell assignment type of Cell center. This means that data that is not located at the center of the cell will not be included in the intermediate rasterized destination output and will not be represented in the distance calculations. For example, if the destinations are a series of small polygons, such as building footprints, that are small relative to the output cell size, it is possible that only a few of them will fall under the centers of the output raster cells, seemingly causing many of the others to be lost in the analysis.
    To avoid this situation, as an intermediate step, you can rasterize the input features directly with the Feature to Raster tool and set the Field parameter. Then use the resulting output as input to the particular distance tool you want to use. Alternatively, you can select a small cell size to capture the appropriate amount of detail from the input features.
  • Before generating an optimal path, one of the following tools is typically used to create a distance accumulation raster and a back direction raster: Distance Accumulation or Distance Allocation. A distance accumulation raster and a back direction raster are required inputs to generate an optimal path.
  • The optimal path created can be a flow path based on D8 flow direction. To generate an optimal path in this way, use a D8 flow direction raster as input for the Input Back Direction or Flow Direction raster parameter. You also need to provide an Input Distance Accumulation Raster value; the Input Distance Accumulation Raster value is not used to determine the path. Whether you use a constant raster or a digital elevation model (DEM), the path will be the same; only an attribute value on the path will vary. See the Flow Direction tool documentation for more information about D8 flow direction rasters.
  • The values on the output optimal path represent the number of paths at a given location. In many cases, paths follow the same route, leaving a source and diverging to go to different destinations. For example, a value of 1 indicates that there is only one optimal path at a given location, while a value of 5 means at that location, there are five optimal paths going through that cell in the study area.
  • To create paths that cross the edge of the projection, the rasters used as inputs for the Input Distance Accumulation Raster and Input Back Direction Raster parameters must have been created at the full global extent, in either a cylindrical projection or a geographic output coordinate system, while using the Geodesic option for the Distance Method parameter.
  • To generate correct optimal paths, the Cell size, Snap raster, Output coordinate system, and Extent environment settings are ignored. The cell size, origin, output spatial reference, and extent of the resulting optimal path raster will align with that of the input back direction or flow direction raster.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input Raster or Feature Destinations
An integer raster or feature (point, line, or polygon) that identifies locations from which the optimal path will be determined to the least costly source.
If the input is a raster, it must consist of cells that have valid values for the destinations, and the remaining cells must be assigned NoData. Zero is a valid value.
Raster Layer; Feature Layer
The distance accumulation raster that will be used to determine the optimal path from the sources to the destinations.
The distance accumulation raster is usually created with the Distance Accumulation or Distance Allocation tool. Each cell in the distance accumulation raster represents the minimum accumulative cost distance over a surface from each cell to a set of source cells.
Raster Layer
Input Back Direction or Flow Direction Raster
The back direction raster contains calculated directions in degrees. The direction identifies the next cell along the optimal path back to the least accumulative cost source while avoiding barriers.
The range of values is from 0 degrees to 360 degrees, with 0 reserved for the source cells. Due east is 90, and the values increase clockwise (180 is south, 270 is west, and 360 is north).
Raster Layer
Destination Field
(Optional)
The field that will be used to obtain values for the destination locations.
Field
Path Type
(Optional)
Specifies a keyword defining the manner in which the values and zones on the input destination data will be interpreted in the cost path calculations.
  • Each zone—For each zone on the input destination data, a least-cost path will be determined and saved on the output raster. With this option, the least-cost path for each zone begins at the cell with the lowest cost distance weighting in the zone.
  • Best single—For all cells on the input destination data, the least-cost path will be derived from the cell with the minimum of the least-cost paths to source cells.
  • Each cell—For each cell with valid values on the input destination data, a least-cost path will be determined and saved on the output raster. With this option, each cell of the input destination data is treated separately, and a least-cost path is determined for each cell.
String
Return value
Output Optimal Path as Raster
The output raster.
Raster
Environments
Auto Commit, Compression, Current Workspace, Output CONFIG Keyword, Pyramid, Scratch Workspace, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
