001286: Rows and columns must be greater than zero.
The number of rows or columns parameters have a value that is less than or equal to zero. Valid values are greater than zero.
Solution
If you are using the Add Rasters to Mosaic Dataset tool, ensure that the Minimum Rows or Columns parameter has a value greater than zero.
If you are using the Define Overviews tool, ensure that the Number of Rows and Number of Columns parameters have values greater than zero.
