001890: Invalid subnetwork connectivity, multiple subnetwork controllers with different subnetwork names found. <value>
A subnetwork controller feature was found with an inconsistent subnetwork name. This occurs when performing a subnetwork trace or executing the Update Subnetwork tool when multiple subnetwork controllers are traversable to one another but do not have the same subnetwork name.
The error will report the subnetwork names and the global IDs of the subnetwork controller features that are inconsistent, for example, [[Subnetwork1], [Subnetwork2], [{Global ID 1}], [{Global ID 2}]].
Learn more about inconsistent subnetworks
Solution
Reference the subnetwork names and Global IDs from the error to locate the subnetwork controllers with inconsistent subnetwork names. If the error was returned from the Update Subnetwork tool, errors will also be generated for the subnetwork controller features with inconsistent subnetwork names.
If the subnetwork name for the subnetwork controller is wrong, rename it using the Modify Subnetwork Controller pane.
If the subnetwork controller should not be defining the subnetwork, break traversability by disconnecting the controller from the rest of the subnetwork features.
