002034: Network attribute's data type must match field's data type.
When assigning a network attribute using the Set Network Attribute tool, an error occurs when the data type of the network attribute does not match the field's data type.
Review the network attribute field type and compare it to the data type of the field to which you are attempting to assign the network attribute. The network attributes for the network can be reviewed in the network properties:
Solution
Ensure that the data types match when assigning network attributes.
