002535: A general warning has occurred while running a trace.
There are several instances when a warning can occur when using the Trace tool. The error will include a specific warning.
The following are specific examples:
Substitution(s) map to multiple values.
No loops were discovered.
No path was discovered.
No isolating feature was discovered.
Multiple subnetwork controllers with different subnetwork names found.
Multiple subnetwork controllers from different tiers found.
Some starting points were ignored because no valid subnetwork controllers were found.
Shortest path trace type has been deprecated.
Solution
This is an informational warning message. No action is necessary.
You can review the trace type for the specific requirements.
To learn about the deprecation of the shortest path trace type and how to use the path trace trace to return the shortest path, see Discover valid paths.
