002784: Cannot have more than one table of the same role: '<value>'.
A role can only be used once per locator.
Solution
Do one of the following:
Assign a role to only one primary table.
Combine the reference data tables that require the same role into a single dataset using the Merge tool.
To create a locator that uses multiple primary tables with the same roles, create a composite locator using the Create Composite Address Locator tool.
