002840: Target feature dataset must contain a feature class called Stops.
The target feature dataset does not have a feature class named Stops, which is required to run the tool.
Solution
Add a valid feature class named Stops to the target feature dataset. Follow the format defined by the ArcGIS Network Analyst extension public transit data model. You can create the feature class manually, or you can create it, along with other required data model tables, using the GTFS To Network Dataset Transit Sources tool.
