GTFS To Network Dataset Transit Sources (Conversion Tools)
Summary
Converts one or more General Transit Feed Specification (GTFS) public transit datasets to a set of feature classes and tables that represent the transit stops, lines, and schedules in the format defined by the Network Analyst public transit data model.
Legacy:
This tool was renamed GTFS To Public Transit Data Model and moved to the Public Transit Tools toolbox at ArcGIS Pro 2.9.
The transit data model feature classes and tables produced by this tool are as follows:
  • Stops
  • LineVariantElements
  • LVEShapes (optional)
  • Calendars
  • CalendarExceptions
  • Lines
  • LineVariants
  • Runs
  • ScheduleElements
  • Schedules
The output from this tool can be used as input to the Connect Network Dataset Transit Sources To Streets tool to prepare all necessary inputs for a transit-enabled network dataset. The complete workflow for creating such a network dataset is described in Create and use a network dataset with public transit data.
Usage
  • The data from all input GTFS datasets will be combined into the same set of output tables and feature classes. The typical motivation for using multiple input GTFS datasets is to model a metropolitan area in which multiple transit service providers operate in the same geographic area.
  • The tool performs some validation on each input GTFS dataset to check for common data problems. When a problem is found, the tool issues a warning and does not process that dataset. The tool output will include data from only those input GTFS datasets that were successfully processed. If some GTFS datasets are processed successfully and others are not processed because of data problems, you can fix the data problems and append the fixed GTFS datasets to the existing tool output by running the tool again with the Append to existing tables parameter checked.
  • Each input GTFS dataset must contain the stops.txt, routes.txt, trips.txt, and stop_times.txt files, and either the calendar.txt or calendar_dates.txt file, or both. The frequencies.txt file will be used if it is present. The shapes.txt file will be used if it is present and you choose to output the LVEShapes feature class.
  • Although GTFS allows blank values for the arrival_time and departure_time fields in the stop_times.txt file, exact times are required by the Network Analyst public transit data model for consumption by the Public Transit evaluator in the network dataset. Check the Interpolate blank stop times parameter to estimate arrival and departure times for an input GTFS dataset with a stop_times.txt file that does not have explicit values for all arrival_time and departure_time fields.
  • The tool constructs the Stops feature class using the latitude and longitude values from the stop_lat and stop_lon fields in the GTFS stops.txt file.
  • The stop_lat and stop_lon fields in the GTFS stops.txt file define the latitude and longitude of stops. These fields are permitted by the specification to be null if the stop's location_type field has a value of 3 or 4. However, because this tool creates geographical features to represent stops, it cannot map stops that have no latitude or longitude. Consequently, stops with location_type values of 3 or 4 that have null values for stop_lat or stop_lon will be skipped and not included in the tool's output.
  • The tool constructs the LineVariantElements features by creating a straight line between each pair of stops that is directly connected by a transit trip.
    The LineVariantElements features are not intended to represent the actual geographic paths taken by buses, trains, or other public transit vehicles but are instead representative of logical connections in the transit system. LineVariantElements features are not meant to be used for visualization. The Public Transit evaluator in the network dataset will use the public transit schedules to determine the travel time required to traverse a LineVariantElements feature, so its shape and length are irrelevant. However, you can edit the shapes of the LineVariantElements features manually, but do not split or merge the features or disconnect them from their adjacent stops.
    For cartographic visualization of public transit lines, you can use the Make LVEShapes from shapes.txt parameter to create the LVEShapes feature class from the shapes.txt file.
  • The tool takes longer to run when generating the optional LVEShapes feature class.
  • If more than one GTFS route provides service between the same two stops, one LineVariantElements feature will be created per GTFS route_id value providing the service. For example, if bus 10 and bus 47 both travel between the same two stops with no other stops in between, the tool will generate two LineVariantElements features, one for bus 10 and one for bus 47. These two line feature will be geographically coincident.
  • Because the public transit data model requires feature classes and tables with specific names, you cannot include more than one set of public transit data model feature classes and tables in the same geodatabase. Do not include the target feature dataset in a geodatabase with an existing feature dataset containing public transit data model feature classes.
  • If the target feature dataset is in an enterprise geodatabase, it must not be versioned. Before running the tool, reconcile and post the data in the feature dataset and unregister it as versioned.
Parameters
Label Explanation Data type
Input GTFS Folders
One or more folders containing valid GTFS data. Each folder must contain the GTFS stops.txt, routes.txt, trips.txt, and stop_times.txt files and either the calendar.txt or calendar_dates.txt file, or both.
Folder
Target Feature Dataset
The feature dataset where the transit-enabled network dataset will be created. The Stops, LineVariantElements, and LVEShapes feature classes created by this tool will be placed in this feature dataset, and the output tables created by this tool will be placed in this feature dataset's parent geodatabase.
The feature dataset can be in a file geodatabase or an enterprise geodatabase and can have any spatial reference. If the target feature dataset is in an enterprise geodatabase, it must not be versioned. Do not include the target feature dataset in a geodatabase with an existing feature dataset containing public transit data model feature classes. Do not use a feature dataset in a mobile geodatabase if you intend to create a network dataset using the output.
Feature Dataset
(Optional)
Specifies whether blank values from the arrival_time and departure_time fields in the GTFS stop_times.txt file will be interpolated when creating the public transit data model tables.
  • Checked—Blank values will be interpolated using simple linear interpolation. The original GTFS data will not be altered. If there are no blank values in the original data, no interpolation will occur.
  • Unchecked—Blank values will not be interpolated. If blank values are found in the input GTFS data, the tool will issue a warning and will not process the GTFS dataset. This is the default.
Boolean
(Optional)
Specifies whether the input GTFS datasets will be appended to existing public transit data model feature classes and tables in the target feature dataset and its parent geodatabase.
  • Checked—Data will be appended to the existing feature classes and tables.
  • Unchecked—Existing feature classes and tables will be overwritten. This is the default.
Boolean
(Optional)
Specifies whether the LVEShapes feature class will be created using the shapes.txt file in the GTFS dataset.
The LVEShapes feature class is not used by the network dataset for routing but can be used for improved output visualization with the Calculate Transit Service Frequency tool.
  • Checked—The LVEShapes feature class will be created.
  • Unchecked—The LVEShapes feature class will be not be created. This is the default.
Boolean
Derived output
Updated Target Feature Dataset
The feature dataset to which the new feature classes have been added.
Feature Dataset
Output Stops
The Stops feature class for the Network Analyst public transit data model.
Feature Class
Output Line Variant Elements
The LineVariantElements feature class for the Network Analyst public transit data model.
Feature Class
Output Calendars
The Calendars table for the Network Analyst public transit data model.
Table
Output Calendar Exceptions
The CalendarExceptions table for the Network Analyst public transit data model.
Table
Output Lines
The Lines table for the Network Analyst public transit data model.
Table
Output Line Variants
The LineVariants table for the Network Analyst public transit data model.
Table
Output Runs
The Runs table for the Network Analyst public transit data model.
Table
Output Schedule Elements
The ScheduleElements table for the Network Analyst public transit data model.
Table
Output Schedules
The Schedules table for the Network Analyst public transit data model.
Table
Output LVEShapes
The LVEShapes feature class for the Network Analyst public transit data model.
Feature Class
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
