003098: Record ObjectID = <value> from the '<value>' input feature class has wrong bounding box coordinates values. Extent value will be calculated from the geometry.
Invalid bounding box values were encountered while building a locator and cannot be used to calculate the extent of each feature in the reference data. The invalid bounding box values are ignored and the default extent values of the reference data are used instead. The bounding box values are used to zoom effectively to geocode and search results in client applications.
Solution
Do one of the following:
Ignore the warning if the default extent value is appropriate for zooming to geocode and search results.
Correct the bounding box values for the record or records mentioned in the message by assigning the values in the reference data using the Calculate Geometry Attributes tool.
