003320: The connected portal's federated servers do not meet the minimum supported release for the <value> - <value>
When creating or upgrading a utility network, the minimum version for ArcGIS Server is 10.7. If the portal's federated server is an earlier release, the operation cannot be completed.
When creating or upgrading a trace network, the minimum version for ArcGIS Server is 10.9. If the portal's federated server is an earlier release, the operation cannot be completed.
Solution
Ensure that the active portal has a federated server that meets the minimum version for the utility network or trace network and run the tool again.
Learn more about ArcGIS system compatibility for the utility network
Learn more about ArcGIS system compatibility for the trace network
