003344: One of your fields is named using a reserved field name. '<value>' has been renamed to '<value>' in your geocoding output.
A field in the Input Table parameter value has a field name that is reserved for geocoding operations and will be renamed. This warning occurs when one of the following fields exists in the input table and the Output Fields parameter is set to Minimal:
  • AddNum
  • Addr_type
  • BuildingType
  • BuildingUnit
  • LevelName
  • LevelType
  • Loc_name
  • Match_addr
  • Match_type
  • Score
  • Status
  • StDir
  • StName
  • StPreDir
  • StPreType
  • StType
  • UnitName
  • UnitType
If using the Split Address Into Components tool, a field in the Input Address Data parameter value has a field named Status and will be renamed. This field name is reserved for reviewing the split address components in the Split Address Review pane.
If using the Assign Streets To Points tool, a field in the Input Point Features parameter value has a reserved field name and will be renamed. This warning occurs when an extra ObjectID field exists in the input point features.
Solution
Do one of the following:
  • Do nothing. The field will be renamed automatically.
  • Rename the field without the reserved word.
