030352: The network dataset template was created from a network dataset that was not upgraded to the current software release version. This template cannot be used to create a network dataset.
The network dataset used to create the template was created with an earlier software version. Because the network dataset schema has changed since the network was created, this template cannot be used to create a new network dataset.
Solution
Run the Upgrade Dataset tool on the network dataset used to create the template to upgrade it to the latest version; then regenerate the template file using the Create Template From Network Dataset tool.
