030386: Cannot create a network dataset from a template that uses Field Script or Element Script evaluators configured with the VBScript language.
Field Script and Element Script evaluators using the VBScript language are no longer supported as of the ArcGIS Pro 3.5 release. You can no longer create or build a network dataset with these types of evaluators. The network dataset template is unusable with the current software.
Learn more about types of evaluators used by a network
Solution
Choose a different network dataset template or re-create the network dataset template after updating the network dataset used to create it.
To update the network, update its evaluators to the Python language, rebuild the network, and create the template again with the Create Template From Network Dataset tool.
