110560: <value1> features have no neighbors with non-zero weights. Features with no neighbors (only includes first 30): <value2>
The specified neighborhood or kernel bandwidth resulted in at least one feature that had no neighbors other than itself or had neighbors whose weights were all equal to zero (or very close to zero). The ID values of the input features with no neighbors with nonzero weights are displayed in the message.
Solution
For the Bivariate Spatial Association (Lee's L) tool, the message is informative and no action is required.
For the Spatial Autoregression tool, all features must have neighbors with positive weight.
To resolve the error or warning, if you are using a fixed distance band neighborhood, increase the value of the Distance Band parameter so that every input feature has at least one other feature closer than the distance band. If you provided a value for the Kernel Bandwidth parameter, increase the bandwidth to a value so that every feature has at least one other neighbor within the bandwidth distance.
