120273: The tool you are running requires more memory to compute the result.
The GeoAnalytics Desktop tool you are running requires more memory than is currently available.
Solution
If possible, increase the amount of memory available on your machine and verify that you have set the Parallel Processing Factor environment high enough.
If you cannot modify the memory, read the help for the tool you are running to see if there are any parameter changes you can make. The following are examples:
Use a smaller bin size when possible.
Use a subset of the data.
Learn more about considerations for GeoAnalytics Desktop tools
