130031: Unable to derive M units.
The m-units could not be automatically determined based on the x,y tolerance and m-tolerance values of the feature class or feature dataset.
Solution
The m-tolerance value cannot be altered once a feature class has been created. The x, y tolerance value must be converted to an m-tolerance value. You must re-create the feature class and assign the correct m-tolerance value.
Learn more about converting an x,y tolerance value based on units in ArcGIS Pipeline Referencing to get the m-tolerance value
Learn more about converting an x,y tolerance value based on units in ArcGIS Roads and Highways to get the m-tolerance value
