180004: You must have an Advanced license, a Spatial Analyst license, and a 3D Analyst license to run this tool.
The tool requires an ArcGIS Pro Advanced license, and both the ArcGIS Spatial Analyst extension and the ArcGIS 3D Analyst extension to be licensed. The following are conditions in which the required licensing may not be available:
  • An ArcGIS Pro Basic or ArcGIS Pro Standard license was authorized.
  • The Spatial Analystextension or the 3D Analyst extension was not assigned or checked out.
  • The Spatial Analyst extension or 3D Analyst extension license has expired.
  • When licensed for Concurrent Use, there isn't a Spatial Analyst or 3D Analystextension license available to check out for use.
Solution
The following solutions correspond to the conditions listed in the Description field:
  • Authorize an ArcGIS Pro Advanced license. You may need to contact your system administrator for assistance.
    Learn more about ArcGIS Pro licensing levels
  • Assign or check out the Spatial Analyst extension, 3D Analyst extension, or both. You may need to contact your system administrator.
    Learn more about extensions
  • Assign or check out licenses that are not expired. You may need to contact your system administrator.
  • If Spatial Analyst and 3D Analyst are enabled, colleagues on your network may be using all of the available licenses. Ask colleagues who aren't actively using the extensions to close their ArcGIS Pro session. Frequent occurrences may warrant acquiring additional licenses.
