An overview of the Features toolset
The Features toolset contains tools that create cartographic features for topographic products.
Tool |
Description |
Applies surround element values to target features. |
Calculates the magnetic field at point locations for a given date and altitude. |
Calculates the maximum elevation figures (MEF) for each polygon cell or quadrangle in a polygon layer. These values are used as labels for the MEF feature layer. |
Generates the features necessary for display in an adjoining sheets diagram on a specification-driven topographic map. |
Creates data required for an elevation guide diagram surround element as required by various supported map product specifications. This tool uses existing banding and thinning parameters to generate output elevation band features, spot height features, and hydrology features. |
Generates isomagnetic lines based on the World Magnetic Model. |
Generates location diagram features for a Joint Operations Graphic (JOG), Operational Navigation Chart (ONC), or Tactical Pilotage Chart (TPC) map sheet. The location diagram must include JOG_Index features, WAC_Index features, ONC_Index features, or LandPoly features for the area surrounding the processed sheet. |
Creates elevation point features based on contour tops and depressions. Elevation points are created in each top and depression. Point height values are populated based on a digital elevation model. |
Creates and smooths contours from an input raster. |
Identifies types of contours and applies hypsographic codes to input features. |
Validates that spot heights are higher than or equal to their respective contour top, and based on the contour interval, that a contour top is not missing a contour line between it and a spot height. |
