Disable Network Topology (Utility Network Tools)
Summary
Disables the network topology for an existing utility network.
Starting with ArcGIS Enterprise 10.9.1, the disable network topology operation will process asynchronously using the UtilityNetworkTools geoprocessing service when working with a utility network in an enterprise geodatabase. The UtilityNetworkTools service is preconfigured in the System folder for feature services that include a utility network. It has a longer time-out setting and is reserved for utility network geoprocessing tasks.
Usage
The topology must be disabled when adding, importing, or deleting rules.
For enhanced performance, it is recommended that you disable the topology before loading data and importing
.csvassociation files.When working with an enterprise geodatabase, the following are requirements:
If using a database connection, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
If referencing a service, the active portal account must be the portal utility network owner.
Only a single session can run the disable network topology operation at a time.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network where the network topology will be disabled. |
Utility Network; Utility Network Layer |
Derived output
Updated Utility Network |
The updated utility network. |
Utility Network |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
