An overview of the Administration toolset
The Administration toolset contains tools to design and administer utility networks.
Tool |
Description |
Adds a color scheme definition for features in a utility network's telecom domain network. Color schemes are used to identify fiber strands, cables, and connectors in telecommunication systems. Each color scheme includes a hierarchical definition with multiple levels in which each level has its own labels, capacities, and delimiters. |
Adds a color set to define the individual colors that may be reused across color schemes in a utility network's telecom domain network. Color sets provide a standardized color library which can be consumed by color schemes in your network using the Add Color Scheme tool. |
Adds a traditional domain network to a utility network. |
Adds a network attribute to a utility network. |
Adds a network category to an existing utility network. |
Adds a network rule to a utility network. |
Adds a telecom domain network to a utility network. |
Adds a terminal configuration to an existing utility network. |
Creates a new tier for a domain network in a utility network. |
Adds a tier group to a domain network in a utility network. |
Adds a wavelength scheme to a utility network's telecom domain network. |
Populates the |
Creates a utility network in an enterprise, file, or mobile geodatabase feature dataset. |
Deletes a color scheme from a telecom domain network. Each color scheme includes a hierarchical definition with multiple levels in which each level has its own labels, capacities, and delimiters. |
Deletes a network category in a utility network. |
Permanently deletes a rule from a utility network. |
Deletes a terminal configuration from a utility network. |
Disables the network topology for an existing utility network. |
Creates a |
Enables a network topology for a utility network. |
Exports associations from a utility network to a comma-separated-values file ( |
Exports the contents of the circuit management tables from a telecom domain network for the specified component type. The data is saved as |
Exports connectivity, structural attachment, and containment rules from a utility network into a comma-separated values file. |
Exports subnetwork controllers from a utility network to a |
Imports associations from a comma-separated values file ( |
Imports circuit information from a series of |
Import connectivity, structural attachment, and containment rules from a comma-separated values file into an existing utility network. |
Imports subnetwork controllers from a |
Rebuilds the network topology in a specified extent to address errors identified during a validate network topology or trace operation. |
Verifies and repairs inconsistencies identified in the network topology system tables. |
Alters the association role assigned to a network feature class or table at the asset type level. |
Sets the properties for circuits in a telecom domain network. |
Defines how features will connect to a line or edge object of a given asset type. |
Assigns a network attribute to a feature class or table at the asset type level to be used during tracing operations. |
Assigns a network category to a feature class or table at the asset type level to be used during tracing operations. |
Sets the domain network tier's properties for a subnetwork in a utility network. |
Sets the combine policy for grouped junction and edge objects in a telecom domain network to determine how attribute values will be handled during a combine operation. |
Sets the divide policy for grouped junction and edge objects in a telecom domain network to determine how attribute values will be handled during a divide operation. |
Assigns a terminal configuration to an asset type in a utility network. |
Verifies the network topology system tables and logs inconsistencies to an output log file. |
