Import Subnetwork Controllers (Utility Network Tools)
Summary
Imports subnetwork controllers from a .csv file into a utility network.
The .csv file generated by the Export Subnetwork Controllers tool can be used as input to this tool. The imported .csv file will modify properties on existing features in the utility network to set those features as subnetwork controllers.
Usage
When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
Subnetwork controllers must be in the correct CSV format and contain the required columns.
Features listed in the
.csvfile must exist in the utility network and meet the prerequisites to be set as a subnetwork controller.The information in the
.csvfile follows this format:SUBNETWORKCONTROLLERNAME,FEATUREGLOBALID,FEATURECLASSNAME,FEATUREASSETGROUP,FEATUREASSETTYPE,FEATURETERMINAL,TIERNAME,SUBNETWORKNAME,DESCRIPTION,NOTES..csvcolumnsColumn
Example
SUBNETWORKCONTROLLERNAMEThe name of the subnetwork controller set on the device or junction object.
South Side Substation
FEATUREGLOBALIDThe global ID of the subnetwork controller feature.
{1CAF7740-0BF4-4113-8DB2-654E18800028}
FEATURECLASSNAMEThe feature class or table of the subnetwork controller feature.
ElectricDistributionDevice
FEATUREASSETGROUPThe asset group of the subnetwork controller feature.
Circuit Breaker
FEATUREASSETTYPEThe asset type of the subnetwork controller feature.
Air Powered
FEATURETERMINALThe terminal of the subnetwork controller feature.
Load
TIERNAMEThe name of the tier to which the subnetwork controller feature belongs.
Medium Voltage
SUBNETWORKNAMEThe name of the subnetwork in which the subnetwork controller participates.
RMT003
DESCRIPTIONThe description of the subnetwork controller.
CB1
NOTESAny notes entered for the subnetwork controller.
RMT003 Substation
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network to which the subnetwork controllers will be imported. |
Utility Network; Utility Network Layer |
Input File |
The |
File |
Derived output
Updated Utility Network |
The updated utility network. |
Utility Network |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
