Export Subnetwork Controllers (Utility Network Tools)
Summary
Exports subnetwork controllers from a utility network to a .csv file.
Subnetwork controllers are features that have been set as subnetwork controllers in the Modify Subnetwork Controller pane. The exported .csv file will contain information about the device features that are currently set as subnetwork controllers. The .csv file generated by this tool can be used as input to the Import Subnetwork Controllers tool.
Learn more about exporting subnetwork controllers
Usage
  • One or more subnetwork controllers must be present in the specified utility network.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
  • The information in the .csv file follows this format: SUBNETWORKCONTROLLERNAME, FEATUREGLOBALID, FEATURECLASSNAME, FEATUREASSETGROUP, FEATUREASSETTYPE, FEATURETERMINAL, TIERNAME, SUBNETWORKNAME, DESCRIPTION, NOTES.
    .csv columns
    Column
    Example
    The name of the subnetwork controller set on the device or junction object.
    South Side Substation
    FEATUREGLOBALID
    The global ID of the subnetwork controller feature.
    {1CAF7740-0BF4-4113-8DB2-654E18800028}
    FEATURECLASSNAME
    The feature class or table of the subnetwork controller feature.
    ElectricDistributionDevice
    FEATUREASSETGROUP
    The asset group of the subnetwork controller feature.
    Circuit Breaker
    FEATUREASSETTYPE
    The asset type of the subnetwork controller feature.
    Air Powered
    FEATURETERMINAL
    The terminal of the subnetwork controller feature.
    Load
    TIERNAME
    The name of the tier to which the subnetwork controller feature belongs.
    Medium Voltage
    SUBNETWORKNAME
    The name of the subnetwork in which the subnetwork controller participates.
    RMT003
    DESCRIPTION
    The description of the subnetwork controller.
    CB1
    NOTES
    Any notes entered for the subnetwork controller.
    RMT003 Substation
Parameters
Label Explanation Data type
The utility network from which subnetwork controllers will be exported.
Utility Network; Utility Network Layer
Output File
The location and name of the .csv file to be generated.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
