Export Associations (Utility Network Tools)
Summary
Exports associations from a utility network to a comma-separated-values file (.csv). This tool can be used in conjunction with the Import Associations tool.
Learn more about how to export associations
Usage
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
  • The information in the .csv file is stored in the following format: ASSOCIATIONTYPE, FROMFEATURECLASS, FROMASSETGROUP, FROMASSETTYPE, FROMGLOBALID, FROMTERMINAL, TOFEATURECLASS, TOASSETGROUP, TOASSETTYPE, TOGLOBALID, TOTERMINAL, ISCONTENTVISIBLE, PERCENTALONG.
Parameters
Label Explanation Data type
The utility network containing the associations to export.
Utility Network; Utility Network Layer
Association Type
Specifies the type of association to export.
  • All—All association types in the utility network will be exported to a .csv file.
  • Junction-junction connectivity—Connectivity associations allowing two junction subtypes to connect via a connectivity association (features are offset geometrically) will be exported to a .csv file.
  • Containment—The containment association type will be exported to a .csv file.
  • Attachment—The structural attachment association type will be exported to a .csv file.
  • Junction-edge connectivity (from side of edge)—The junction-edge (from side of edge) connectivity association type will be exported to a .csv file.
  • Junction-edge connectivity (midspan)—The junction-edge (midspan) connectivity association type will be exported to a .csv file.
  • Junction-edge connectivity (to side of edge)—The junction-edge (to side of edge) connectivity association type will be exported to a .csv file.
String
Output File
The name and location of the .csv file that will be generated.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
