Export network associations
You can export a collection of associations from a utility network into a CSV file using the Export Associations tool.
With this tool, you can export one type of association to a single CSV file (for example, only containment) or several types of associations (for example, containment, connectivity, and structural attachments).
See Associations for more information on each type of association.
Requirement
To export a network association, the following requirement must be met:
- When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
Steps
To export network associations, complete the following steps:
On the Analysis tab, in the Geoprocessing group, click Tools
to open the Geoprocessing pane.In the Geoprocessing pane, search for and select Export Associations.
For the Input Utility Network parameter, enter the utility network from which to export associations.
From the Association Type drop-down parameter, choose the type of association to export:
All
Junction-junction connectivity
Containment
Junction-edge connectivity (from side of edge)
Junction-edge connectivity (midspan)
Junction-edge connectivity (to side of edge)
In the Output File parameter, specify a location and name for the
.csvfile to be generated.Click Run to execute the tool.
The selected types of association have been exported to the specified .csv file. Refer to the Export Associations tool help to understand the format of the output CSV file.
