Import Associations (Utility Network Tools)
Summary
Imports associations from a comma-separated values file (.csv) into an existing utility network. This tool can be used in conjunction with the Export Associations tool.
Learn more about how to import associations
Usage
  • Associations must be in a single .csv file.
  • Features listed in the .csv file must exist in the utility network.
  • Features listed in the .csv file must have supporting rules.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
  • The information in the .csv file is stored in the following format: ASSOCIATIONTYPE, FROMFEATURECLASS, FROMASSETGROUP, FROMASSETTYPE, FROMGLOBALID, FROMTERMINAL, TOFEATURECLASS, TOASSETGROUP, TOASSETTYPE, TOGLOBALID, TOTERMINAL, ISCONTENTVISIBLE, PERCENTALONG.
    When the Input Utility Network parameter references a utility network that contains a telecom domain network, the .csv file requires four additional columns: FROMFIRSTUNIT, FROMLASTUNIT, TOFIRSTUNIT, and TOLASTUNIT. When a telecom domain network is present, these header fields are required even if the target domain network is a traditional domain network. To learn more, review the Associations table help topic.
    .csv columns
    Column
    Example
    ASSOCIATIONTYPE
    The type of association.
    • Junction Junction Connectivity
    • Junction Edge From Connectivity
    • Junction Edge Midspan Connectivity
    • Junction Edge To Connectivity
    • Containment
    • Structural Attachment
    Containment
    FROMFEATURECLASS / TOFEATURECLASS
    The feature class or object participating in the association.
    ElectricDistributionDevice, ElectricDistributionAssembly, StructureJunction
    FROMASSETGROUP / TOASSETGROUP
    The asset group of the feature.
    Transformer, Fuse, Elbow
    FROMASSETTYPE / TOASSETTYPE
    The asset type of the feature.
    Streetlight, Attachment, Single-phase padmounted
    FROMGLOBALID / TOGLOBALID
    The global ID of the feature.
    {16558C73-013C-4169-A095-7E9DCD57EB57}
    FROMTERMINAL / TOTERMINAL
    The terminal participating in the association. This is only applicable to junction-junction connectivity associations.
    Single Terminal, Load, Source
    ISCONTENTVISIBLE
    A Boolean flag indicating whether the content is visible. This is only applicable to containment associations.
    False, True
    PERCENTALONG
    The percent along value for junction-edge midspan connectivity associations between a junction object and an edge object.
    0.75
    FROMFIRSTUNIT / TOFIRSTUNIT
    The first unit ID of the FROM or TO side grouping. This is only required when the Input Utility Network parameter references a utility network that contains a telecom domain network.
    FROMLASTUNIT / TOLASTUNIT
    The last unit ID of the FROM or TO side grouping. This is used along with the From and To first unit attributes to determine the size of the contiguous group that is connected on the FROM or TO side. This is only required when the Input Utility Network parameter references a utility network that contains a telecom domain network.
    12
Parameters
Label Explanation Data type
The utility network to which the associations will be imported.
Utility Network; Utility Network Layer
Association Type
Specifies the type of association that will be imported.
  • All—All association types will be imported.
  • Junction-junction connectivity—The junction-junction connectivity association type will be imported.
  • Containment—The containment association type will be imported.
  • Attachment—The structural attachment association type will be imported.
  • Junction-edge connectivity (from side of edge)—The junction-edge connectivity (from side of edge) association type will be imported.
  • Junction-edge connectivity (midspan)—The junction-edge connectivity (midspan) association type will be imported.
  • Junction-edge connectivity (to side of edge)—The junction-edge connectivity (to side of edge) association type will be imported.
String
Input File
The .csv file from which the associations will be imported.
File
Derived output
Updated Utility Network
The updated utility network.
Utility Network
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
