Associations table
The Associations table stores information about all associations in a utility network. It is a system-maintained table that is hidden by default. Each row represents an association and information about the features or objects that participate in the association. Information in this table is updated when the topology is enabled or validated and when changes are made to an association using the Modify Associations pane or through ArcGIS REST API.
When working with a telecom domain network, this table is used along with foreign-key attributes on the domain classes to model associations. Association foreign keys decrease the number of association records required to model systems with a large number of nonspatial objects such as telecom networks.
With the telecom domain network, the associations table is not used to manage junction-edge from, or junction-edge to connectivity associations to an edge object nor containment associations. Instead, foreign keys on the domain classes are used to model the association. When adding containment associations, if the feature already has a container, the content features are added to the associations table.
The Associations table stores information about the following:
  • The associations in a utility network
  • The features or objects that participate in an association
  • Whether an association has been modified or is in error
  • Editor tracking details for association records
The Associations table contains the following attributes:
Field name
Field alias
OBJECTID
Object ID
The object ID for the record in the table.
FROMNETWORKSOURCEID
From network source ID
The unique identifier for the From network source in the utility network.
FROMGLOBALID
From global ID
The global ID of the From feature or object in the association.
FROMTERMINALID
From terminal ID
The terminal ID of the From feature or object in the association (if applicable).
TONETWORKSOURCEID
To network source ID
The unique identifier for the To network source in the utility network.
TOGLOBALID
To global ID
The global ID of the To feature or object in the association.
TOTERMINALID
To terminal ID
The terminal ID of the To feature or object in the association (if applicable).
ASSOCIATIONTYPE
Association type
The association type.
Values are the following:
  • Junction-Junction Connectivity association = 1​
  • Containment association = 2​
  • Structural Attachment association = 3​
  • Junction-Edge From Connectivity association = 4
  • Junction-Edge Midspan Connectivity association = 5
  • Junction-Edge To Connectivity association = 6
ISCONTENTVISIBLE
Is content visible
A Boolean flag indicating whether the content is visible. This is only applicable to containment associations.
PERCENTALONG
Percentage along
The percent along value for junction-edge midspan connectivity associations between a junction object and an edge object.
STATUS
Status
The status value is used to communicate whether the association or its participating features or objects have been modified.
Learn more about how to interpret Status field values
ERRORCODE
Error code
Errors on the association are displayed using a bit encoded value that can represent one or more errors. An association with an error code of 0 indicates a record with no errors.
ERRORMESSAGE
Error message
Additional contextual information associated with the error.
CREATIONDATE
Creation date
The date the association was created.
CREATOR
Creator
The user who created the association.
LASTUPDATE
Last update
The last time the row in the table was updated.
UPDATEDBY
Updated by
The last user to update a row in the table.
GLOBALID
Global ID
The global ID of the row in the table.
The Association table contains the following additional attributes to support connectivity between grouped objects in telecom domain networks. These fields are added to the table when the first telecom domain network is created in a utility network:
Field name
Field alias
FROMFIRSTUNIT
From first unit
The first unit ID of the From side grouping in the association.
FROMLASTUNIT
From last unit
The last unit ID of the From side grouping in the association. This is used with the FROMFIRSTUNIT attribute to determine the size of the contiguous group that is connected on the From side of the association.
TOFIRSTUNIT
To first unit
The first unit ID of the To side grouping in the association.
TOLASTUNIT
To last unit
The last unit ID of the To side grouping in the association. This is used with the TOFIRSTUNIT attribute to determine the size of the contiguous group that is connected on the To side of the association.
Access the Associations table
The Associations table is a system-maintained table that is hidden by default. You can use the From Path option on the Add Data drop-down menu to add the Associations table to a map. This can be used to provide context and support conflict management when conflicts are detected on an association record. To add the table, provide the service URL path appended with the layer ID for the Associations table (500001) as shown in the following example: https://myserver.domain.com/server/rest/services/<service name>/FeatureServer/500001.
The table is added to the map in the Contents pane under Standalone tables.
Interpret Status field values
The Status attribute field value indicates whether modifications have been made to an association or the features and objects that participate in the association. The values displayed in the attribute field represent decimal values that correspond with a bit encoded value. The following table outlines the status bit values and how these are presented in the Status field:
Status bit
Status field value
N/A
The association is not dirty or deleted.
The association is deleted.
The feature or object on the From side of the association is deleted.
The feature or object on the To side of the association is deleted.
The association is dirty.
The object on the From side of the association is dirty.
32
The object on the To side of the association is dirty.
For example, a status bit of 4 would be represented in the Status field as 16 (2^4 = 16) and indicate that the object on the From side of the association has been modified and is dirty. An association record that has not been modified or deleted does not have a bit value set and is represented with a Status attribute value of 0. These values are summated when multiple modifications are made to an association record. For example, a Status attribute value of 49 indicates that the From and To object in the association is dirty and that the association itself has been deleted: (2^4 + 2^5 + 2^0) = 49, and a Status attribute value of 56 indicates that the From and To object in the association, and the association itself, are dirty: (2^3 + 2^4 + 2^5) = 56.
