Export Rules (Utility Network Tools)
Summary
Exports connectivity, structural attachment, and containment rules from a utility network into a comma-separated values file.
Usage
  • The information in the .csv file includes the following columns: RULETYPE, FROMFEATURECLASS, FROMASSETGROUP, FROMASSETTYPE, FROMTERMINAL, TOFEATURECLASS, TOASSETGROUP, TOASSETTYPE, TOTERMINAL, VIAFEATURECLASS, VIAASSETGROUP, VIAASSETTYPE, and VIATERMINAL.
    .csv columns
    Column
    Example
    RULETYPE
    The type of rule.
    Junction Junction Connectivity, Junction Edge Connectivity, Edge Junction Edge Connectivity, Containment, Structural Attachment
    FROMFEATURECLASS, TOFEATURECLASS
    The feature class participating in the rule.
    ElectricDistributionDevice, ElectricDistributionAssembly, StructureDevice
    FROMASSETGROUP, TOASSETGROUP
    The asset group participating in the rule.
    Arrester, BreakerBank, JunctionBox, Switch
    FROMASSETTYPE, TOASSETTYPE
    The asset type participating in the rule.
    Tie Switch, Padmount, Overhead hood stick, Overhead gang operated
    FROMTERMINAL, TOTERMINAL
    The terminal participating in the rule. An asterisk (*) indicates that the rule applies to all terminals if the asset type has terminals.
    Single Terminal, Load, Source
    VIAFEATURECLASS, VIAASSETGROUP, VIAASSETTYPE, VIATERMINAL
    These columns are used only for edge-junction-edge connectivity rules. These are the connecting feature class, asset group, asset type, and terminal that are included in the rule.
    ElectricDistributionLine, Medium Voltage, Single Phase Overhead, Load
  • The output of this tool can be used as input to the Import Rules tool.
  • When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
Parameters
Label Explanation Data type
The utility network to export the rules from.
Utility Network; Utility Network Layer
Rule Type
The type of rule to export.
  • All—All the rules in the utility network will be exported.
  • Junction-junction connectivity—Junction-junction connectivity association rules will be exported.
  • Junction-edge connectivity—Junction-edge connectivity rules will be exported.
  • Containment—Containment association rules will be exported.
  • Structural attachment—Structural attachment association rules will be exported.
  • Edge-junction-edge connectivity—Edge-junction-edge connectivity association rules will be exported.
String
Output File
The folder location and name of the .csv file to be created.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
