Import Rules (Utility Network Tools)
Summary
Import connectivity, structural attachment, and containment rules from a comma-separated values file into an existing utility network.
Usage
  • The information in the .csv file includes the following columns: RULETYPE, FROMFEATURECLASS, FROMASSETGROUP, FROMASSETTYPE, FROMTERMINAL, TOFEATURECLASS, TOASSETGROUP, TOASSETTYPE, TOTERMINAL, VIAFEATURECLASS, VIAASSETGROUP, VIAASSETTYPE, and VIATERMINAL.
    .csv columns
    Column
    Example
    RULETYPE
    The type of rule.
    Junction Junction Connectivity, Junction Edge Connectivity, Edge Junction Edge Connectivity, Containment, Structural Attachment
    FROMFEATURECLASS, TOFEATURECLASS
    The feature class participating in the rule.
    ElectricDistributionDevice, ElectricDistributionAssembly, StructureDevice
    FROMASSETGROUP, TOASSETGROUP
    The asset group participating in the rule.
    Arrester, BreakerBank, JunctionBox, Switch
    FROMASSETTYPE, TOASSETTYPE
    The asset type participating in the rule.
    Tie Switch, Padmount, Overhead hood stick, Overhead gang operated
    FROMTERMINAL, TOTERMINAL
    The terminal participating in the rule. An asterisk (*) indicates that the rule applies to all terminals if the asset type has terminals.
    Single Terminal, Load, Source
    VIAFEATURECLASS, VIAASSETGROUP, VIAASSETTYPE, VIATERMINAL
    These columns are used only for edge-junction-edge connectivity rules. These are the connecting feature class, asset group, asset type, and terminal that are included in the rule.
    ElectricDistributionLine, Medium Voltage, Single Phase Overhead, Load
  • For containment rules, the FROM entry must be the container and the TO entry must be the content. Regarding structural attachment rules, the FROM entry must be the structure and the TO entry must be the structural attachment. Entry ordering does not pertain to junction-junction, junction-edge, and junction-edge-junction connectivity rules.
  • This tool can be used in conjunction with the Export Rules tool.
  • The network topology must be disabled.
  • When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
Parameters
Label Explanation Data type
Specifies the utility network to import the rules to.
Utility Network; Utility Network Layer
Rule Type
Specifies the type of rules to import.
  • All—One or more types of rules
  • Junction-junction connectivity—Junction-junction connectivity association rules
  • Junction-edge connectivity—Junction-edge connectivity rules
  • Containment—Containment association rules
  • Structural attachment—Structural attachment association rules
  • Edge-junction-edge connectivity—Edge-junction-edge association rules
String
Input File
Specifies the .csv file containing the rules to import.
File
Derived output
Updated Utility Network
The updated utility nework.
Utility Network
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
