Rebuild Network Topology (Utility Network Tools)
Summary
Rebuilds the network topology in a specified extent to address errors identified during a validate network topology or trace operation.
This tool is used to rebuild the network topology and repair inconsistencies when you encounter failures that prevent the validate network topology or trace operations from completing. This operation ignores dirty areas and applies to all features in the specified extent. The Rebuild current extent command on the Utility Network tab uses synchronous processing, while this tool uses asynchronous processing.
The asynchronous rebuild operation uses the UtilityNetworkTools geoprocessing service. The UtilityNetworkTools service is preconfigured in the System folder for feature services that include a utility network. It has a longer time-out setting and is reserved for utility network geoprocessing tasks.
Usage
The network topology must be enabled.
When you rebuild a network topology based on a specific extent, the dirty areas that intersect the specified extent are clipped.
When working in an enterprise deployment, the following are requirements:
The input utility network must be a utility network service from ArcGIS Enterprise 10.9 or later.
When working with the default version, only a single session can run the rebuild operation at a time. While the rebuild operation is running, the network remains accessible for editing and tracing.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network for which the network topology will be rebuilt. |
Utility Network; Utility Network Layer |
Extent |
Specifies the geographical extent that will be used to rebuild the network topology.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates. |
Extent |
Derived output
Rebuilt Utility Network |
The rebuilt utility network. |
Utility Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
