Add Wavelength Scheme (Utility Network Tools)
Summary
Adds a wavelength scheme to a telecom domain network.
Usage
  • The Input Utility Network parameter value must reference a utility network version 8 or later.
  • The utility network dataset provided for the Input Utility Network parameter must include a telecom domain network.
  • The Wavelength Scheme Name parameter value must be unique in the domain network and cannot exceed 256 characters.
  • The Wavelengths parameter's Wavelength Name property value must be alphanumeric and cannot exceed 10 characters.
  • The Wavelengths parameter's Wavelength Length property value must be a positive integer or double.
  • The following requirements must be met when working with an enterprise geodatabase:
Learn more about how to add a wavelength scheme
Parameters
Label Explanation Data type
The input utility network containing the wavelength scheme that will be added.
Utility Network; Utility Network Layer
Domain Network
The telecom domain network containing the wavelength scheme that will be added.
String
The name of the wavelength scheme that will be added.
String
Wavelengths
Properties that describe the wavelengths created in the wavelength scheme.
Value table columns:
  • Wavelength Name—The name of the wavelength in the wavelength scheme. Examples of values include Channel 1 or 1270nm.
  • Wavelength Length—The length of the wavelength in nanometers, for example, 1270 or 1550.00.
Value Table
Derived output
Output Utility Network
The updated utility network.
Utility Network
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
